Help to built my network
Apr 8th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-fareast-language:EN-US;} /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-fareast-language:EN-US;}
Hello
I have a network that works well : 2 remotes sites and one central site connected by wireless link
Each remote site have 1 Cisco 2801 and the central site have 1 Cisco 2821
VPN are configured between each remote site and the central site
The Linksys router serves as my gateway to the Internet on central site
And I have several servers on my central site.
Users who are in their offices(remote and central site) have access to the servers without problem.
I am planning 2 things
1.       VoIP calls : install CCME on Cisco 2821 and install Cisco phone (FL-CCME-48 on cisco 2821 , 5 ip phone cisco 7945 G and 30 ip phone cisco 7911G)
2.       Secured access for user to the server via internet (cisco 2821 + L-CCME-48 or asa 5520)
I want users who are outside of our offices can also access these servers from the Internet,
This access must be secured, they can use cvpn-client-k9=
These users use Windows XP or vista and Internet Explorer.
Please have a look on attachment and tell me if solution 1 and solution 2 can work
Please could you help me to choose which solution is the best ?
Leo Laohoo Thu, 04/08/2010 - 16:18
Yikes, VPN wireless link.
What BW is your proposed link to the internet?
nicanor00 Fri, 04/09/2010 - 00:41
I have 512K to internet
But my problem is to know which one of that 2 future solution can work ?
If the 2 solution can work, which is the best in term of quality of service
Leo Laohoo Fri, 04/09/2010 - 15:49
Ho boy!  This is not an easy question.  In my line of work, anything over wireless has ZERO SLA.  It's just too un-reliable.  What type of wireless link do you have in mind?
