etherchannel to servers wont come up
Answered Question
Apr 8th, 2010
im creating etherchannels on a stacked 3750 -lacp but th channel wont come up..is there something wrong w/ my config?
ive shu /no shut all interfaces too
Number of channel-groups in use: 6
Number of aggregators:           6
Group  Port-channel  Protocol    Ports
10     Po10(SD)        LACP      Gi1/0/43(I) Gi2/0/42(I)
interface Port-channel10
switchport access vlan 14
switchport mode access
Current configuration : 144 bytes
interface GigabitEthernet1/0/43
channel-group 10 mode active
spanning-tree portfast
interface GigabitEthernet2/0/42
Correct Answer by Giuseppe Larosa about 7 years 2 weeks ago
Hello Nygenxny123,
yes probably LACP daemons has not been started on server side.
You can check this on the log message of the switch you should see messages telling that no LACP message is seen on port.
I see this multiple times when server people asks us an LACP bundle so we usually configure our side after they do their part on server NICs
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Thu, 04/08/2010 - 08:50
  • Hall of Fame,
    Founding Member
Hello Nygenxny123,
check if interface port-channel is not created in shutdown
in order to have the bundle up when using LACP the other side must talk LACP otherwise after some time member links are removed from bundle if no LACP frames are received on them
so check if server or other switch is configured to use LACP
hope to help
Giuseppe
nygenxny123 Thu, 04/08/2010 - 09:20
i bounced my port-channel10 and still nothing
so from my config its safe to assume the other end/servers..may be having issues?
i wonder why the interface is showing (I)
in summary
droeun141 Thu, 04/08/2010 - 11:56
Your config looks good. I think the (i) means that the port's inactive in the etherchannel group (no LACP packets received), but is still able  to function as an individual link.
Tulsi Ram Puttaraju Thu, 04/08/2010 - 11:59
Could you pls try the configs with
port-channel 1
switchport mode trunk
interface f0/1
switch mode trunk
interf f0/2
switch mode trunk
Not sure if you wanted the Etherchannel in Bundled( P ), right now it is showing( I )because it is stand alone which is correct if you want in access mode.
Tulsi Ram
Correct Answer
Giuseppe Larosa Thu, 04/08/2010 - 13:25
  • Hall of Fame,
    Founding Member
Hello Nygenxny123,
Hope to help
Giuseppe
