AP goes off channel while identifying rogue ap threats
Answered Question
Apr 8th, 2010
I'm having a problem where client connections get dropped, when the AP identifies a rougue ap threat.  In some cases, the client is dropped ever 5 minutes for up to 30 minutes.  My clients are connected over a RADIUS setup authenticating with an IAS service.
Found this on Cisco Support site:
Cisco lightweight access points are known to go off channel for up to 30 seconds (typically 1 to 2 seconds) while identifying rogue access point threats, when the Cisco lightweight access point has RLDP enabled. This can cause client connections to be dropped occasionally (CSCar10047).
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/r1x4x31.html
Should RLDP be disabled enabled?  Is there any work-around for this?
My WLAN Environment:
- Controller - WLC2106; software version 6.0.182.0
- (3) 1242ag Access Points
- (1) 1131ag Access Points
Thanks in advance.
Correct Answer by Rob Simkins about 7 years 3 months ago
If you like keeping clients connected I would disable it
http://www.cisco.com/application/pdf/paws/70987/rogue_detect.pdf
Overall Rating: 5 (1 ratings)
msekula Thu, 04/08/2010 - 13:56
As a troubleshooting step, I have disabled RLDP on all Wireless Networks.
(Cisco Controller) config> rogue detection disable all
I'll monitor and report back after 4 business days.
Trending Topics - Security & Network
