Install/Upgrade not finding files
Answered Question
Apr 8th, 2010
I'm still working the install of the Chinese language pack and the server does not seem to want to find the Chinese locale cm-locale-zh_CN-7.0.1.3000-1.cop.sgn using the FTP search and CD ROM.  We are on CUCM 7.1.3 and this is the latest file I find for CUCM 7.  The search does find similar files such as cmterm-csf-copydialingrules-0.1.cop.sgn, but the drop down has none of the different locale files I've downloaded?  Has anyone else run into this issue?  Should it not be finding locale cm-locale-zh_CN-7.0.1.3000-1.cop.sgn for some other reason that I am unaware of?
Thanks!
Correct Answer by Aaron Harrison about 7 years 3 weeks ago
There is a newer version of that locale : cm-locale-zh_CN-7.1.3.2000-1.cop.sgn
Try that.
Aaron
Overall Rating: 5 (2 ratings)
Correct Answer
Aaron Harrison Thu, 04/08/2010 - 08:32
  • Community Spotlight Award,
    Member's Choice, May 2015
Try that.
Aaron
Rob Huffman Thu, 04/08/2010 - 09:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Keith,
Sorry about that my friend, my previous post was just an example
Like Aaron nicely noted (+5 "A"). here is the path for 7.1(3)
Cisco> Support>Tools and Resources> Software Downloads>  Voice and Unified Communications  > IP Telephony > Call Control> Cisco Unified Communications  Manager Version 7.1  > Unified Communications  Manager/CallManager Locale Installer > 7.1.(3.2000-1)  > cm-locale-zh_CN-7.1.3.2000-1.cop.sgn   >
Cheers!
Rob
