Option to Manage Thresholds in DFM not available
Apr 8th, 2010
Hi I'm running DFM 3.2.0 and when I tried to expand the tab to manage threshold on interfaces nothing is there.
I tried rebooting the server to see if it fixes the problem no luck.
I am able to expand Device type groups and make changes, not for the DFM or User defined group.
I was able to last week though.
dionjiles Thu, 04/08/2010 - 11:24
To give you an example:
Under DFM>Configuration>Managing Thresholds> I'm able to expand Device Type groups i.e. Routers, Sec. and VPN, etc.
For DFM which has the access port groups and such.....when I click on the expand button nothing shows up.
dionjiles Fri, 04/09/2010 - 02:57
Yes I have.
-Dion
On Apr 9, 2010, at 2:21 AM, "jclarke"
Joe Clarke Fri, 04/09/2010 - 23:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the logs under NMSROOT/log/dfmLogs/PTM.
Joe Clarke Mon, 04/12/2010 - 15:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There appears to be an OGS problem.  Have you tried rebooting the entire server?  You may be seeing a bug where the DfmServer processes don't actually a terminate on Daemon Manager shutdown.  A reboot would confirm that.
dionjiles Mon, 04/12/2010 - 16:04
That's what I assumed....I have rebooted the server several times.
-Dion
On Apr 12, 2010, at 6:36 PM, "jclarke"
Joe Clarke Tue, 04/13/2010 - 11:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the output of:
NMSROOT/objects/smarts/bin/brcontrol
And post the DFMOGSServer.log.
dionjiles Tue, 04/13/2010 - 11:56
I'm having truoble finding this log file.
DFMOGSSErver.log
Also brcontrol seems to be an application.
Joe Clarke Tue, 04/13/2010 - 12:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I wanted you to run the brcontrol program, and post the output.
Joe Clarke Tue, 04/13/2010 - 12:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You should have seen output from brcontrol in the DOS window from which you ran it.  What was that output?
Joe Clarke Tue, 04/13/2010 - 12:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What is the output of:
NMSROOT/bin/perl NMSROOT/bin/resolver.pl pmplwnet1800.corp.citistreet.org
Joe Clarke Tue, 04/13/2010 - 13:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the NMSROOT/objects/smarts/local/logs/DFM.log and DFM1.log.
Joe Clarke Tue, 04/13/2010 - 22:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It looks like something may be wrong with your DFM repository files.  Try shutting down Daemon Manager, then delete NMSROOT/objects/smarts/local/repos/icf/DFM.rps and DFM1.rps.  Then restart Daemon Manager, and see if you can modify threshold settings.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
dionjiles Wed, 04/14/2010 - 06:31
Thanks for the advice....I performed the following steps and even rebooted did not fix my issue.
Joe Clarke Wed, 04/14/2010 - 19:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You could try a full reinit of the DFM databases, but that would cause all of your DFM customizations to be lost.  The instructions can be found at https://supportforums.cisco.com/docs/DOC-8796 .  However, it might be better to open a TAC service request so real-time debugging can be done.
dionjiles Wed, 04/14/2010 - 20:13
Hi thanks for your help....
I tried the reinit of the database several times,......I will open
a TAC case.
-Dion
On Apr 14, 2010, at 10:39 PM, "jclarke"
