CCM 4.2 SQL version mismatch
Answered Question
Apr 8th, 2010
All other boxes in the cluster are showing SQL version 8.00.2050 except one box that I have just recently added showing version 8.00.2039.
I'm not a SQL guy. Any instructions on how to bring this one to the same version level as the others would be greatly appreciated. I don't see any replication issue here though, just wanted to make sure the version aligns.
Thanks.
Correct Answer by Aaron Harrison about 7 years 2 months ago
The OS SR will cause reboots, but there is no reason to do anything to the cluster. You certainly wouldn't want to remove a server from the cluster for any reason (unless you've no intention of putting it back).
You can run every server in your cluster on different OS versions; it's the version of CCM that is most important (though obviously it's good practice to be consistent and up-to-date).
So in summary - just run it same as you did before.
Aaron
Overall Rating: 5 (1 ratings)
Aaron Harrison Thu, 04/08/2010 - 08:48
  • Community Spotlight Award,
    Member's Choice, May 2015
As I recall, the SQL patches/SRs are included in the OS updates.
If you run the 'OS Version' applet from the Start Menu, are they all on the same version/SR of the Cisco OS build?
Aaron
ktran-anet Thu, 04/08/2010 - 08:58
Yes they are. Obviously, that was the first thing I looked at and be sure the OS and SR's are the same before I join it to the cluster. The only think left I know I must do is to reboot the cluster which I have already scheduled in 2 weeks time. So I think it's a good time to upgrade the SQL version to the same level as the others and reboot them all.
Aaron Harrison Thu, 04/08/2010 - 09:27
Well - that version of SQL appears to be associated with MS08-040. If you check the release notes for the latest version of your OS, you should be able to see where it was introduced; probably in whatever SR you are running. It might be worth re-running that, or extracting the patch from it (I think they actually go into a temp directory somewhere in program files, so you might find it there and run the SQL patch on it's own). Failing that just get the patch from MS and install it.
Aaron
Please rate helpful posts..
ktran-anet Thu, 04/08/2010 - 10:36
Alright, thanks for the hint. I think I would need a hotfix of MS08-040 (win-K9-MS08-040-Windows2000.exe). Unfortunately, I couldn't find this file from CCO. There is a next version up, i.e. win-K9-MS08-045-Windows2000.exe. Any words about this version of hotfix?
Aaron Harrison Thu, 04/08/2010 - 12:26
Well, no.. you want to keep within the patches that Cisco have tested and published for you...
Did you try reapplying the SR?
Try taking a look for a directory like this:
C:\Program Files\Cisco\Updates\2003.1.x_common
There should be something similarly named that contains the various patches that make up the SR.
Aaron
ktran-anet Thu, 04/08/2010 - 12:53
Just looked and compared the folders you have mentioned (mine is C:\Program Files\Cisco\Updates\2000.4.x_common) and I have noticed that there are different in size and also number of files. Would it be any problem reinstalling the SR while it is connected to the cluster? Should I do it offline then reconnect it?
Correct Answer
Aaron Harrison Thu, 04/08/2010 - 12:56
Aaron
ktran-anet Thu, 04/08/2010 - 14:09
You're the man. Reinstalling the SR appears to get it back on track. Thanks a lot for your information and I really appreciate it.
Aaron Harrison Fri, 04/09/2010 - 00:05
No problem
