L2L VPN with nat
Answered Question
Apr 8th, 2010
HI All
I am quite inexperienced on this subject and would greatly appreciate guidance on this
I need to create a VPN tunnel between our site and a remote site.
On our site, we are a 192.168.0.X network our external ip address is 12.53.150.100
The site we will need to connect to is 69.144.38.48
We need to have it go from host to host meaning 192.168.0.97 --> 69.144.38.50 and they want our ip to be translated to 10.9.250.1
Thanks in advance
Jason
Correct Answer by droeun141 about 7 years 2 weeks ago
Are you familiar with setting up a regular L2L tunnel? in addition to that, you would just need to create a policy nat:
access-list 100 extended permit ip host 192.168.0.97 host 69.144.38.50
static (inside,outside) 10.9.250.1 access-list 100
When defining your crypto ACL, you would specify 10.9.250.1 as the source instead of 192.168.0.97.
Let me know if you need any more help.
Overall Rating: 5 (1 ratings)
jnarenkivicius Thu, 04/08/2010 - 11:12
Hi,  Thanks for the quick reply
Sorry I not too savy with this device+
I have created the L2L tunnel before using the ASA 5505 VPN wizard.
can you explain that a little more
Jason
droeun141 Thu, 04/08/2010 - 11:41
Is it a PIX or an ASA? did the remote side give you any of their config? phase 1, phase 2, etc.
Correct Answer
droeun141 Thu, 04/08/2010 - 10:57
Related Content
