Archive Command - Sequencing
Apr 8th, 2010
Hi folks,
I'm using the archive command to backup the config of a switch to a tftp server every time a user enters the write memory command. The problem that I have is that a sequence number is automatically added to the end of the file name. The commands I'm using are below. I've also tried removing the $h and specifying a file name but to no avail.
The only 2 switches I can find in documentation are $h and $t. The first makes the filename the name of the switch, the second timestamps the file name. I'm hoping there's one that stops the sequence number being added to the file name.
path tftp://$h
Thanks for looking
