Fair-Queue on Serial Interfaces that belong to Multilink Group
Apr 8th, 2010
I have 2 T1's bundled in a Multilink Group.  I have a QOS Policy assigned to the Multilink interface for prioritizing VOIP packets.  Everything that I read tells me that the serial interfaces themselves should have "no fair-queue" set and I currently have it that way.  I have noticed that our latency across the Private Lines that make up the Multilink Group is all over the place, nothing consistant with what a private line should look like.  As a test one night I enabled "fair-queue" on the serial interfaces and my latency numbers dropped big time making the connection look like a Private Line again.  I am puzzled on what configuration I am using and why I saw the results that I did.  Any advice would be greatly appreciated.
Paolo Bevilacqua Thu, 04/08/2010 - 13:07
Sometime, documentation or common advice is wrong, and you find the best results by trial and error.
bfledderjohn Thu, 04/08/2010 - 14:21
Thanks for the reply.  I will have to do some more testing to qualify this.  What is your opininion on the use of the command "ppp multilink fragment disable" on a Multilink interface?  It seems that my research shows that is a good thing to have in place.
Paolo Bevilacqua Thu, 04/08/2010 - 14:52
Fragmentation should be disabled for most cases and uses.
Please remember to rate useful posts clicking on the stars below, what will help Cisco contribute in help of Haiti.
