Cisco PIX 506e Password Reset Issue
Apr 8th, 2010
Hi all;
I trying to do password reset on a 506e that I got with the current password unknown.  I've gone to the Cisco URL for the reset:
http://www-tss.cisco.com/eservice/compass/common/activities/password_PIX.htm
monitor> interface 0
0: i8255X @ PCI(bus:0 dev:13 irq:10)
1: i8255X @ PCI(bus:0 dev:14 irq:7 )
Using 0: i82559 @ PCI(bus:0 dev:13 irq:10), MAC: 0050.54ff.82b9
monitor> address 192.168.100.140
monitor> server 192.168.100.52
monitor> file np63.bin
file np63.bin
monitor> ping 192.168.100.52
Sending 5, 100-byte 0xf8d3 ICMP Echoes to 172.18.125.3, timeout is 4 seconds:
Success rate is 100 percent (5/5)
monitor> tftp  then I get this:
TFTP failed (return -1 arg 0x0)
I am using the correct bin file as I checked with my pix version.  Also I CANNOT ping the firewall from a PC
or system on the network, but CAN ping everthing from the PIX.
I've tried using interface 1 but no go.  Also I've checked the TFTP software (Solarwinds) is running fine and
I've unblocked it in XP's firewall.
Kind of stumped on this one.  Any help would be grately appreciated.
Thanks, Steve
vitokyan777 Thu, 03/28/2013 - 16:41
I did everything in the manual, but I see a message - tftp failed (return -12 arg: 0x0). ping works, tftp server logs I see attempts to download, but they will fail with "Failed (Timeout Error)."
what could be the problem? tried both the interface, there is no result.
