COBRAS Data Viewer error 3709
Answered Question
Apr 8th, 2010
Hey guys --
I am currently getting an error while running COBRAS Data Viewer, as soon as I run the application and select the database that I exported, I get the following error:
(error): 3709 (The connection cannot be used to perform this operation.  It is either closed or invalid in this context.) in procedure listHandlers_Click of From frmMain
I have to click 'OK'  couple times to clear the message.  Then everytime I select a subscriber, the same error appears.
Any thoughts?
Ohamien
Correct Answer by lindborg about 6 years 10 months ago
hmmm... not sure what's up with that.
Moved it to the primary download site:
http://www.ciscounitytools.com/Applications/General/COBRAS/COBRAS.html
build 26 should be out there now.
Overall Rating: 5 (1 ratings)
lindborg Thu, 04/08/2010 - 13:35
What version of the data viewer are you using?
What version and product backup are you trying to open?
ouhakheme Thu, 04/08/2010 - 13:41
Lindborg, you are insane. =)
Thanks for the quick reply.  I am running Data Viewer version 1 Build 25.
Trying to open a Unity Connection backup Version 7.1.3.  Oddly enough, when I open the UnityDataDB backup it gives the error; however, when I try to open the UnityMessage backup, it seems to work fine.
Any help is appreciated.
Ohamien
lindborg Thu, 04/08/2010 - 13:48
hmmm... I'm running build 25 as well and I just opened several 7.1(3) backups I have - no problems.  Can you select the "Backup Details" option
and post for me the details it kicks out for your backup?  i'm guessing the backup was made with an older version of Export and a column name it's expecting to be there in the backup is not - i'll need to add logic so "if version is less than X" it doesn't attempt to fish that value.
ouhakheme Thu, 04/08/2010 - 13:53
Build 50 of Export.
Unity Connection version=7.1(3.68)
Backed up with Export version=1.0.50
User name that ran backup=ouhakhe
Domain name backup was run from=WORKGROUP
Back up ran from server name=IBM-C2150A12B77
Backed up started at: 04/08/2010 16:01:48
Backed up server name= 10.18.199.18
lindborg Thu, 04/08/2010 - 14:01
ah... opposite problem - the latest version of export includes additional SMTP data (proxy addresses among other things) - looks like it's trying to fetch that but bungling on me - let me get a fix for it real quick...
ouhakheme Thu, 04/08/2010 - 14:37
Works like a champ!  Thanks for the great help and immediate response.  Much appreciated!
You are the man Lindborg!
Take care,
Ohamien
