04-08-2010 01:35 PM - edited 03-06-2019 10:31 AM
Is there any way to run a cli command that will show how the switches are numbered (1,2,3 and so on) from the front display panel. I want to verify physically the switches in the stack.
Solved! Go to Solution.
04-08-2010 01:45 PM
show switch @ the cli will indicate which is the stack master
from the front panel pressing the mode button until you reach the "stack" setting - all switches will blink the number they are in the stack
from interfce x/1 to x/9
HTH>
Andrew.
04-08-2010 01:45 PM
HTH>
Andrew.
04-08-2010 01:47 PM
Kewl thanks I put these guys in about 4 years ago and have not had to mess with them.
04-08-2010 02:04 PM
Sure :o) , I know how that goes - all good.
Andrew.
