Cisco RME Netconfig
Apr 8th, 2010
Hi all,
I am using CiscoWorks RME 4.0 Netconfig to push some config.  I am creating a new Netconfig job.  After selecting a device (2621XM), I selected my user-defined SSH task.  It didn't show up on the next screen under "Applicable Tasks".  However, if I chose the system defined SSH task for the same device, the system defined SSH task showed up.
Why is my user defined task not showing up?
Thanks!
kevin.hu Thu, 04/08/2010 - 15:09
Never mind, I found out where the problem is.  Under user defined task, you can choose device type to apply the task to.
