Displaying numbers pressed on screen
Answered Question
Apr 8th, 2010
After a call is connected if you press any of the number keys the numbers do not display.  Is there a setting in call manager to turn this on?  I have gone through the admin and system guide and have not found a reference to this.
Thanks in advance.
Correct Answer by Aaron Harrison about 7 years 2 months ago
I had this request once; there was no way to do it then, and I'm not aware of anything changing since...
You see the dialed/connected number, not the DTMF you send afterwards...
Aaron
Correct Answer by Jaime Valencia about 7 years 2 months ago
Unfortunately that's not something you can configure. Once the call is connected the DTMFs are sent but they won't show up in the LCD screen after the DN you dialed.
If you feel this should be a feature, get in touch with your AM and ask him about submitting a PER on this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (2 ratings)
Correct Answer
Jaime Valencia Thu, 04/08/2010 - 15:28
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Correct Answer
Aaron Harrison Fri, 04/09/2010 - 00:13
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
