Fibre connection query re SRW2048 switch
Apr 8th, 2010
Hi, probably a basic question but hoping someone can assist. I have a client with this on site and it has 3x GB connections.  We have connected ST-SC copper fibre converter cables to this however on the other end the fibre switch is only 10/100 and there are no lights on the 2048 GB ports and the cables are not working. I'm wanting to know if its going from GB  to 10/100 that would be the problem?  Thanks for any help.
Reza Sharifi Thu, 04/08/2010 - 17:56
  • Cisco Designated VIP,
    2017 LAN
Hi Mike,
Yes, that is the problem.  The fiber interface is Gig only and does not work with 10/100.  With Fiber both sides have to use the same speed.
Reza
