DAI inspection - Rate limit
Apr 8th, 2010
Hey All,
I've implemented layer 2 security for DAI and DHCP snooping etc
I've set the the following interface command for packets per second.
"ip arp inspection limit rate 100"
But I noticed printers go over the 100 now and then, and the port goes into err-disable.
So questions,
Is 100 a appropriate value? I've never had any user ports have issues as of yet.
Is there a way to make limit rate unlimited for specified mac addresses? as the printers can move around.
Many Thanks,
Alan
Reza Sharifi Thu, 04/08/2010 - 19:28
  • Cisco Designated VIP,
    2017 LAN
Hi Alan,
The values for rate limit are  between 1 and 2048 pps. You may want to raise it to a larger number and see if the printers work correctly.
For untrusted interface the default is 15pps and for trusted is unlimited.
Here is the command reference guide:
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_arp.html#wp1012378
Reza
alanc3141592654 Thu, 04/08/2010 - 20:34
thanks, i've already read through the guide and know the default values.
Raising to a larger value, does make it work. But I was just wondering if there is a way to set up a access list or something, so it still works when the printer moves to a new port..?
i.e there is a arp access-list for devices with static IPs.
Maybe this is not possible.
A
