Performance Problems
Apr 8th, 2010
Appologies all for another "low end" question,
We have an ACE appliance that is in the frame for casuign performance problems.
sh resource usage for the context [there is only one + Admin] show a LARGE [almost 0.75Gb]amount of denies in the bandwidth area. All of the denies are allocated to the management line.
we have snmp tools monitoring the device - but the BW for mgt is the standard 12500000
any ideas ?
thanks
arthurlove Fri, 04/09/2010 - 04:15
Sorry the attachement didnt attach in first post here is the out put
-note that the resource class does not have stick and there is IP sticky configured in the context - need to fix that I guess
       Resource         Current       Peak        Min        Max       Denied
Context: Admin
  conc-connections             19         19          0     600000          0
  mgmt-connections             16         16          0      30000          0
  proxy-connections             0          0          0      78643          0
  xlates                        0          0          0      19661          0
  acc-connections               0          0          0         15          0
  bandwidth                    82    4233152          0  165265318          0
    throughput                 82        456          0   40265318          0
    mgmt-traffic rate           0          0          0  125000000          0
  connection rate               0          1          0     300000          0
  ssl-connections rate          0          0          0        300          0
  mac-miss rate                 0          0          0        600          0
  inspect-conn rate             0          0          0      12000          0
  http-comp rate                0          0          0    3932160          0
  acl-memory                35088      35088          0   11265638          0
  sticky                        0          0          0          0          0
  regexp                     1214       1214          0     314573          0
  syslog buffer                 0          0          0     315392          0
  syslog rate                   0          0          0      30000          0
Context: PROD
  conc-connections           1584     118628    1400000     600000          0
  mgmt-connections              0        326      70000      30000          0
  proxy-connections             0         27     183500      78643          0
  xlates                        0          0      45875      19661          0
  acc-connections               0          0         35         15          0
  bandwidth               1194459  220034959   93952410  165265318  675938304
    throughput            1194459   95034959   93952410   40265318          0
    mgmt-traffic rate           0  125000000          0  125000000  675938304
  connection rate             271       2213     700000     300000          0
  ssl-connections rate          0          0        700        300          0
  mac-miss rate                 0        215       1400        600          0
  inspect-conn rate             0          0      28000      12000          0
  http-comp rate                0          0    9175040    3932160          0
  acl-memory                33272      33272   26284336   11265638          0
  sticky                     1085       1171     573440          0          0
  regexp                      914        914     734003     314573          0
  syslog buffer                 0          0     733184     315392          0
  syslog rate                   0      16760      70000      30000          0
PROD_PRI/Admin#
resource-class PROD_Resource
  limit-resource all minimum 70.00 maximum unlimited
