Sticky question
Apr 9th, 2010
Hi All .. more questions ?
We have a web app that requires sticky sessions. We have to use IP as the marker.
The IP source has comes from a one-2-one NAT range that has a /16 mask.
The sticky config is currently
sticky ip-netmask 255.255.255.255 address source WEB_APP_GP
  replicate sticky
  serverfarm SERV_FARM
this seems to work so far,
Question: should this actually be
sticky ip-netmask 255.255.0.0 address source WEB_APP_GP
  replicate sticky
thanks again for help
Overall Rating: 5 (2 ratings)
ciscocsoc Fri, 04/09/2010 - 00:52
The netmask is used to determine how much of the source address is used to create an entry in the database - i.e. the network component rather than the host component is used.  If you use a /16 mask then the first client to connect will create a sticky database entry and all subsequent clients from your NATTed range will match that entry and be load-balanced to the same server. This is probably not what you want.
I tend to use a /32 mask to balance each client individually but if your clients are evenly distributed across the /16 you could use a /24 mask and create fewer sticky entries in the database.
Cathy
