HUNT GROUP FINAL NUMBER
Apr 9th, 2010
Hi teams,
I have a hunt group with two extension.Using this hunt group i handled the call successfully.Now i created new voice mail box with no 850.Now i wanted to divert the call to this voice mail if any can not picking the phone.
My voice mail pilot number is 893.Please help to solve this problem with all relevent information becuase i am new in this field.
ephone-dn  106  dual-line
number 099 secondary 401
label 099
description RECEPTION1
name RECEPTION1
call-forward busy 893
call-forward noan 893 timeout 10
corlist incoming use900-international
ephone-dn  107  dual-line
number 098 secondary 401 no-reg
label 098
description RECEPTION2
name RECEPTION2
ephone-hunt 1 longest-idle
  pilot 9
list 098, 099
final 850
timeout 30, 30
Plese help me
thanks
David Trad Sat, 04/10/2010 - 16:35
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2013 Small Business
Hi naisamuddin,
Can you please confirm that the VM you created for the hunt-group "850" is a Group Delivery Mail Box (GDM)?
Please also check if the following information is in the running configuration:
voice translation-rule 2002
rule 1 /^6/ //
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 893
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
ephone-dn  86
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 893
The above is only an example, however for your Hunt Group VM:
pilot 9
list 098, 099
final 6850
timeout 30, 30
The above is what I would think you would want to do, this way it goes to the particular Voice Mail, you will also need to make VMB 850 a GDM otherwise it wont work, well not that I can see anyway.
I hope the above makes sense to you.
Did you use CCA 2.2.2 to configure the system?
Cheers,
David.
bchris999 Mon, 04/12/2010 - 08:55
The timeout on the huntgroup has to be shorter than the call-forward noan timeout on the extensions. I ran into the same problem (I assume it gets disconnected instead of going to voicemail), and logged a TAC case for it, however they would not accept this was a bug.... their workaround was using a 3rd extension as an overlay extension instead of a huntgroup, but I dont think this is an acceptable workaround. I am still trying to find a good solution. If anyone else knows, please post here?
