adsl bonding
Apr 9th, 2010
hello every body, I have two adsl lignes, I want do bonding but I have to create vpns with a remote site, I want to know if there is cisco equipment that support bonding (I 'm with two differents ISP), please answer me.
Paolo Bevilacqua Fri, 04/09/2010 - 02:14
There is no cisco or other equipment that can bond circuits like that, and it cannot be done.
sliti.boutheina Fri, 04/09/2010 - 02:49
I 'm sure that there cisco routers that do load balancing, just the problem is with vpn
there will be multi canal vpns
thank you
Paolo Bevilacqua Fri, 04/09/2010 - 09:13
As indicated above, and answering your question, you cannot do load balancing over the internet for a single VPN.
However, other redundancy features are possible when having multiple circuits.
