VPN issue, can't contact hosts on LAN
Apr 9th, 2010
Hi all..
For my work i've been put on a project tot manage the connections to several locations in Yemen.
The connection to the remote routers (IPsec) works well. I mean that I can contact the router via my vpn client using the yemen group. But the thing is that i simply can't reach the hosts on the inside of the remote network.
What in the config can be the problem. Is i the ACL entry?
Maybe you guys can help me out of this.
Any answer can be helpful!
--Config removed-
Overall Rating: 5 (1 ratings)
Jennifer Halim Fri, 04/09/2010 - 02:26
ACL 110 that you have assigned for split tunnel ACL does not seem to exist as per your configuration.
ACL 110 should say:
access-list 110 permit ip
Also, ACL 2 that has been assigned to the NAT statement, needs to be changed to an extended ACL, as follows:
access-list 120 deny ip
access-list 120 permit ip any
ip nat inside source list 120 interface Dialer0 overload
no ip nat inside source list 2 interface Dialer0 overload
Hope that helps.
