WCS 4404 Ramifications of turning on Broadcast forwarding
Apr 9th, 2010
We are trying to get wireless hand held scanners that talk to a GUI on the laptop up and running and found that /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} The laptop has an application installed that sends network broadcasts out to try to communicate with the hand-held scanner. Once the scanner is found by the laptop application then unicast messages are used for communication. We tested and found that the only way it works is when we trun on Broadcast forwarding on the controller. Any help will be appreciated.  Thanks Deena
Trending Topics - Security & Network
