cisco 867 router dsl vpn connection to cisco 3030
Apr 9th, 2010
we have a remote office that has dsl in their office.  we purchased a new Cisco 867 router with an ADSL connection to setup a vpn tunnel to our cisco 3030.  Dose anyone have a working configuration for this setup?
The 867 is a the lasted ver of 15.1.  Not sure what type of dsl connection we have.  Is this important to know?
Paolo Bevilacqua Sat, 04/10/2010 - 05:42
Are you being supported by any professional or certified partner ? That would be the best way to obtain sure results for you networking needs.
broow Tue, 04/20/2010 - 11:11
I think I am close to getting this working.  I can ping from the 867 web addresses both by name and ip address.  I just can not access the web from a work station connected to the 867.  I attached the config file.
thanks
broow Wed, 04/21/2010 - 10:38
have access to the internet now.
time to try and setup vpn tunnel to 3030
broow Thu, 03/17/2011 - 04:51
working for 35 weeks now.  Key is to use Cisoc CP express to setup unit
and know your dsl login and passwords
