04-09-2010 07:18 AM - edited 03-15-2019 10:11 PM
I had issues when running Cisco Unified CM Assistant Configuration wizard for the first time in CCM 7.1(3). Is there a way to run it again?
Thank you
Marcos
Solved! Go to Solution.
04-09-2010 07:41 AM
Hi Marcos,
Here is the actual reference
You can use the Cisco Unified Communications Manager Assistant Configuration Wizard only once. The feature verifies the number of times that the configuration wizard has been run (zero or 1). If the configuration wizard has been run once, the summary window automatically displays. The summary window displays the details and status of the configuration wizard that was previously run. If the configuration has not been run, the configuration process continues.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/admin/7_0_1/ccmfeat/fsipma.html#wpxref39049
Cheers!
Rob
Please support CSC Helps Haiti
04-09-2010 07:41 AM
Hi Marcos,
Cheers!
Rob
04-09-2010 07:47 AM
Thank you Rob
