Native-VLAN and interface BVI on a accesspoint 1242
Apr 9th, 2010
I have to create a configuration for an accesspoint.
There are four VLANs.
VLAN 1 = / 24 = printers
VLAN 2 = / 24 = WLAN 1 for laptops
VLAN 3 = / 24 = WLAN 2 for other mobile devices
VLAN 4 = / 24 = management VLAN for network devices
Now I have two solutions for the config for the accesspoint in relation to the interface BVI.
First and simple one:
I take the bridge-group 1 for the FastEthernet0.4 with encapsulation dot1Q 4 native
and use the default interface BVI 1 with the IP-address / 24.
The default config will leave the bridge-group 1 on the interface Dot11Radio 0 (without usage, right?)
The second solution is not as simple as the first one, but looks fairer:
I create the bridge-group 4 on the FastEthernet0.4 with encapsulation dot1Q 4 native.
I will shutdown the interface BVI 1 and create the new BVI 4 with the IP-address / 24.
I have to create the interface Dot11Radio0.4 with encapsulation dot1Q 4 native to get out the default bridge-group 1 from Dot11Radio0.
It should be possible to shutdown the Dot11Radio0.4 because I don't need WLAN for that VLAN and I don't want to create a SSID and so on.
Is there any design guide from Cisco how to configure that?
Thanks for any help!
