04-09-2010 10:37 AM - edited 03-06-2019 10:32 AM
Hi All,
I am in desperate need for some advise. I have a Cisco 3750 PoE, and when I try to console in to the switch all I get is garbage output. I have the following hyperterminal settings:
9600 baud
8 data bits
1 stop bit
No parity
None (flow control)
I've also tried various different baud values, but all show the garbage.
I have also tried a different console cable and still no joy. I have an identicle switch and this works perfectly fine. I've also checked the configuration register (via the web "Express Screen") and ensured it is set to 0xF.
Does anyone have any other suggestions? Any help would be much appreciated.
Thanks!
04-09-2010 12:38 PM
This particular switch works fine?
I mean couldn't it be that there's a hardware problem with the switch itself?
Have you tried to console in from a different machine?
Some computers when you have the BREAK or another key on the keyboard pressed, will not allow to see the screen in hyperterminal.
Federico.
04-10-2010 01:13 AM
H Federico,
Thanks for your post. The switch itself seems to operate fine, can communicate with two PC's at Layer 2. I haven't however tried consoling from another machine. I will give that a go and let you know!
Many thanks for your help, much appreciated.
Chris
