RLDP error message in 1142n Access point
Apr 9th, 2010
For the past two days i am getting alert from the WCS
WCS 127.0.0.1 has detected one or more alarms of category AP and severity Critical
for the following items:
802.11b/g/n interface of AP AP0022.bd1a.0f46 is down: Controller 172.26.125.5 - Controller Name: ER_WLC1 (2 times)
But it comes up
WCS 127.0.0.1 has detected a change in one or more alarms of category AP and severity Critical.
The new severity of the following items is Clear:
802.11b/g/n interface of AP AP0022.bd1a.0f46 is up: Controller 172.26.125.5 - Controller Name: ER_WLC1 (2 times)
In the log messages of the ap i see the below errors
*Apr  2 00:41:03.654: %LWAPP-5-RLDP: RLDP stopped on slot 0.
*Apr  2 00:41:03.697: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Apr  2 00:41:03.698: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr  2 00:41:03.717: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr  2 19:43:56.323: %LWAPP-5-RLDP: RLDP started on slot 0.
*Apr  2 19:43:56.619: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Apr  2 19:43:56.620: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr  2 19:43:56.638: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr  2 19:44:07.620: %LWAPP-5-RLDP: RLDP stopped on slot 0.
*Apr  2 19:44:07.661: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Apr  2 19:44:07.662: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr  2 19:44:07.681: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr  3 23:02:00.203: %LWAPP-5-RLDP: RLDP started on slot 0.
*Apr  3 23:02:00.494: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Apr  3 23:02:00.495: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr  3 23:02:00.512: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr  3 23:02:21.502: %LWAPP-5-RLDP: RLDP stopped on slot 0.
this error is coming only for this AP..i am trying to disable RLDP on this AP but i am not able do it..so if anyone have any suggestion ple let me know
karthik
dancampb Mon, 04/12/2010 - 06:44
  • Cisco Employee,
Seeing the radio interfaces reset if RLDP is enabled is expected.  The AP needs to reset the radios because while RLDP is running the state of the radios has to be changed so that it can associate to other AP's.  There are bugs filed to have the trap messages be clearer to why the radios reset.
tdhb..hiq Sun, 08/08/2010 - 16:13
I am having similar problems, but we have not RLDP configured.
Whenever a AP changes channels, to reduce noise or interference, I recieve alarms stating as below;
802.11b/g/n interface of AP THA-A-AP-04 is down: Controller 10.218.100.251 Reason: Unknown.
802.11b/g/n interface of AP THA-A-AP-04 is up: Controller 10.218.100.251 Reason: Unknown.
Is there a way to reduce these messages or mitigate them? I still want to know if the AP goes down, but not every time there is a change in channel.
thanks
WCS Version  6.0.196.0
WLC Software Version 6.0.182.0
karthikeyan gop... Mon, 08/09/2010 - 08:44
I upgraded my controllers version to 7.x and I don’t receive these kind of messages at all, usually I used to receive these kind of messages 10 times daily but right now I don’t receive it. May be you can try upgrading the software version.
Karthik
Cristian Bernal Tue, 01/11/2011 - 12:54
I have the same problem with LAP 1140 and WLC 6.0.199.0. I have also problems association and disassociation of the AP (from the wlc) and interruption of service for customers.
Deliver alarms (events) by WCS are as follows:
* 802.11b/g/n interface of AP AP02-AGP10-ERP is up: Controller 10.31.100.5
* 802.11b/g/n interface of AP AP02-AGP10-ERP is down: Controller 10.31.100.5
and
* AP 'AP02-AGP10-ERP' disassociated from Controller '10.31.100.5'.
* AP 'AP02-AGP10-ERP' associated with Controller '10.31.100.5' on Port number '...
The topology includes a WLC ( /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} 6.0.199) - WCS ( /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} 6.0.196) - MSE ( /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} 6.0.105) and LAP 1140 (12.4(21a)JHB).
The upgrade to the 7.x version in WLC was recommended by TAC?
Related Content
