SA520 Protectlink Logging?
Hi All,
The Protectlink URL page on the SA520 will show you how many times a filter instance has been blocked. I would also like to be able to see which client IP address was responsible. Their is a Protectlink page in the loggs section, but even though I am seeing instances blocked on the URL page, the log page shows no info at all. Is it possible, or how can I view more logging info regarding Protectlink? Can it show me a client IP address that caused the block?
biraja Wed, 04/14/2010 - 20:56
Hi Mike,
Please enabled protectlink logs under – Administration->Logging->Logs Facality and Severity.  Also you must go to Administration->Logging->Logging Config and  enable Output Blocking Event Logs.
