04-09-2010 01:47 PM - edited 03-06-2019 10:33 AM
I am trying to create the most simplest of VLAN filters out there, yet it doesn't work. My goal is to filter the traffic on VLAN 3060 to only allow DHCP (so client can get an IP address from our server) DNS, HTTP and HTTPS only. Nothing else.
My configuration below allows my client device to get an IP address, but that's where it ends. I cannot do an nslookup from the DNS server, etc.
Can someone see the error I have overlooked?
vlan filter Guest_WLAN_Protocol_Restriction vlan-list 3060
vlan access-map Guest_WLAN_Protocol_Restriction 10
match ip address Guest_WLAN_Protocol_Restriction
action forward
ip access-list extended Guest_WLAN_Protocol_restriction
permit udp any any eq bootps
permit udp any any eq bootpc
permit udp any any eq domain
permit tcp any any eq domain
permit udp any any eq 80
permit tcp any any eq www
permit tcp any any eq 443
deny ip any any
Tim
04-14-2010 12:55 PM
Hi Tim,
I believe you are missing the dns reply in your access-list, something similar to the following should work:
permit udp any eq domain any gt 1023
Tim
04-15-2010 09:17 AM
Tim,
I figured it out, and you were right on the money. I was missing the return path:
Here's my working solution:
action forward
vlan filter Guest_WLAN_Protocol_Restriction vlan-list 2099
ip access-list extended Guest_WLAN_Protocol_Restriction
permit udp 10.128.254.0 0.0.0.255 any eq domain
permit tcp 10.128.254.0 0.0.0.255 any eq domain
permit icmp 10.128.254.0 0.0.0.255 any echo
permit icmp 10.128.254.0 0.0.0.255 any echo-reply
permit icmp 10.128.254.0 0.0.0.255 any port-unreachable
permit udp 10.128.254.0 0.0.0.255 any eq 80
permit tcp 10.128.254.0 0.0.0.255 any eq www
permit tcp 10.128.254.0 0.0.0.255 any eq 443
deny ip 10.128.254.0 0.0.0.255 any
permit ip any 10.128.254.0 0.0.0.255
Tim
