Maintaining Internal DNS After Connecting to Client VPN
Answered Question
Apr 9th, 2010
We connect to client VPN's all day and I wanted to know if there is a way to still use our Internal LAN DNS while connected. For instance, when I connect to client A's VPN, our internal mail server and dns resolves to the public IP's.
Correct Answer by Jennifer Halim about 6 years 11 months ago
You can configure split-dns feature, but that can only be configured at your client's vpn device because you are only connecting with vpn client and normally vpn client policies get pushed from the vpn headend device.
Here is the split-dns command if your client happens to run ASA firewall, and they allow you to configure it:
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/s8.html#wp1404571
Overall Rating: 5 (1 ratings)
Correct Answer
Jennifer Halim Fri, 04/09/2010 - 15:21
  • Cisco Employee,
jgorman1977 Sat, 04/10/2010 - 08:08
Perfect. I administer the clients ASA, so this won't be an issue. Thank you.
