Eigrp summary route question
Answered Question
Apr 9th, 2010
Hi all,
If we have Router A connected to 3 different networks and is using EIGRP
172.16.5.144/28
172.16.5.160/28
172.16.5.128/28
so what summary route will be shown in output of sh ip route on Router A
many thanks
mahesh
Correct Answer by Nagendra Kumar ... about 7 years 2 weeks ago
Mahesh,
Yes. When you configure eigrp summary address of 172.16.5.128/26, it will have an entry in local RIB pointing to null interface.
Nagendra
Correct Answer by Federico Coto F... about 7 years 2 weeks ago
If you want a single summary statement, the best one is this:
172.16.5.128/26
Just make sure there are no overlapping in any other part of the network.
Federico.
Overall Rating: 5 (2 ratings)
Correct Answer
Federico Coto F... Fri, 04/09/2010 - 16:24
  • Green, 3000 points or more
172.16.5.128/26
Federico.
Nagendra Kumar ... Sat, 04/10/2010 - 02:52
  • Cisco Employee,
Hi Mahesh,
From your description, all 3 networks are connected to Router A. So it all will be shown as connected route in routing table. There wont be any summary route generated by default.
If you configure a EIGRP summary, an entry pointing to null interface will be installed in your routing table.
HTH,
Nagendra
mahesh18 Sat, 04/10/2010 - 07:44
thanks for reply
so if i config this as summm router then entry in routing table will be
172.16.5.128/26  and it points to null table right?
mahesh
Correct Answer
Nagendra Kumar ... Sat, 04/10/2010 - 07:57
  • Cisco Employee,
Mahesh,
Nagendra
