How to debug B-ACD issues?
Apr 9th, 2010
I have a UC520 with a B-ACD group configured with CCA 2.2.1.  When you call the pilot, you receive dead air then a busy signal after a bit.  I've done some debugging, and the correct dial-peer is being reached.  What debug commands can I use to get more information?  I have deleted the entire B-ACD config from CCA and removed the scripts in flash.  I also cleaned up the config by hand because CCA left a couple of ephone-dns behind.  After cleaning, I rebooted, and then configured from scratch.  CCA uploaded the scripts first of couse.  Still didn't help.
Any thoughts?
Thanks.
Marcos Hernandez Mon, 04/12/2010 - 08:31
Hi Joe,
Could you please open a case for this issue?
Interesting debugs are:
"debug voip ccapi inout", "debug voip dialpeer".
Marcos
