CCME & Exchange 2007 unified messaging Call relay problem
Answered Question
Apr 9th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
hello guys
I have just been trying to expand  my knowledge on unified communitation.  I am using CCME and exchange server 2007.
I have set up exchange unified messaging role and I can connect to my voice mail box and activate my mail box.  I can even change my mail box pin from the phone. But my call forward no answer is not working .  when a call is not answered,  the call does not go the the receivers mail box but just simply goes to exchange messaging server default prompt.
Guys has anyone ever encountered this problem?
cheers
Here   is the config I used cheers
dial-peer voice 550 voip
description ** Exchange Unified Messaging **
destination-pattern 550
session protocol sipv2
session target ipv4:192.168.10.4
session transport tcp
dtmf-relay rtp-nte
codec g711ulaw
fax rate disable
fax protocol pass-through g711ulaw
no vad
telephony-service
voicemail 550
sip-ua
mwi-server ipv4:192.168.10.4 expires 3600 port 5060 transport udp
ephone-dn 1
call-forward busy 550
call-forward noan 550 timeout 18
ephone-dn 1
Correct Answer by sidris-sid about 7 years 1 month ago
you need to make sure that the users (IP Phones) is already enable UM role from Exchange side with the same Cisco Extension (UM role Ext = Cisco IP Phone Ext).
Actually its working with me fine .....I think no need for SIP UA account.
SID
Overall Rating: 5 (1 ratings)
Correct Answer
sidris-sid Sat, 04/10/2010 - 07:08
SID
Sarg . Wed, 04/14/2010 - 19:12
thanks for helping. i did not even know someone had replied. i will test this tomorrow.
when you said i need a sip-ua account. do u mean :
a) i need to make my router a sip-ua
b) i need to use sip phones
c) i need to create a sip-ua on exchange server
thanks
Sarg . Wed, 04/14/2010 - 19:43
oh sorry u said no need. i d rushed throught it when i first read it. ok i've just started the lab. i will get working on it and tell you how it goes. but i think i already add the phone number but ill just go over it again should in case i missed it.
thanks
Sarg . Tue, 04/20/2010 - 06:39
  It works perfectly. The mistake I made was that I use the same number for the automated attendant pilot number. I am really impressed with how Microsoft made it simple to generate scripts in the background without even having programming knowledge. . . so much easier than Cisco. But I am very disappointed with the message waiting indicator failure. Do you know of any message waiting indicator software I can install apart from mwi2007 from  www.mwi2007.com ?   I tried this site but they don’t seem to have a trial versions and this Is just a lab environment so I can’t afford to spend? Have ever tried any message waiting indicator software?
thanks
Aaron Harrison Tue, 04/20/2010 - 06:57
  • Community Spotlight Award,
    Member's Choice, May 2015
"I am really impressed with how Microsoft made it simple to generate scripts in the background without even having programming knowledge. . . so much easier than Cisco"
What does that mean? What kind of scripts are you referring to?
Aaron
Sarg . Tue, 04/20/2010 - 08:20
I'm talking about /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} customizing the automated attendant steps and also  how to responds to dialed DTMF inputs for call transfers when an incoming call is routed to the hunt pilot. manipulating  cisco scripts with an editor is not as easy for me.Or is there something I don't know?
cheers
