SPA 3102 only detects disconnect tone while line is ringing
Answered Question
Apr 9th, 2010
My provider offers a Speedtouch 780WL (locked) as CPE which provides two FXS ports. I wanted to use a software based PBX so I bought a couple of SPA 3102 Gateways. After a little experimenting, I found that Norway's disconnect tone pattern (as it is provided in the Cisco ATAs manual) seemed to work the best with the 780WL's FXO ports. However, to my surprise it turned out that the SPA will detect the disconnect tone while the line is ringing, but will fail to do so during a call! Here's an example:
Inbound call ---> nobody answers the phone ---> Remote caller hangs up ---> SPA successfully detects disconnect tone
Inbound call ---> call picked from a SPA941 ----> After the conversation ends, the remote caller hangs up first ---> SPA3102 fails to detect disconnect tone.
In the latter case, I can hear the tone through the SPA941's handset, the VoIP call is not terminated and the SPA3102 still lists "PSTN Line"'s hook status as "hook off"...
Does anybody have any idea on what is to blame here? Better off, does anybody have SPA settings that work with the Speetouch?
Correct Answer by samsonluk about 7 years 2 months ago
Downgrade it and you will be fine
Sent from my iPod
Correct Answer by Alberto Montilla about 7 years 2 months ago
Dear sir, please revert to 5.1.7. There is an issue related to tone detection which may be related to your case. Let us know the results.
Alberto
What firmware version in your SPA3102?
Overall Rating: 5 (3 ratings)
Correct Answer
samsonluk Fri, 04/09/2010 - 23:52
Correct Answer
Alberto Montilla Sat, 04/10/2010 - 09:42
  • Cisco Employee,
Alberto
Correct Answer
samsonluk Sat, 04/10/2010 - 16:15
Sent from my iPod
georgediam Sun, 04/11/2010 - 11:06
I downgraded to 5.1.7, but unfortunately the problem is far from gone...This is really annoying if one wants to send calls to voicemail: it will record the disconnect tone forever...
What really troubles me is that I can hear a second periodic sound of the same frequency, which sounds more like ticking than a disconnect tone and which is not audible if I connect a regular analogue phone to one pf the FXS ports of the Speedtouch router. Does this ring a bell to anyone?
Alberto Montilla Mon, 04/12/2010 - 02:33
  • Cisco Employee,
Dear Sir;
This is very strange, first time I hear of this issue on the SPA3102. I suggest you take traces (ethereal for example) in both cases: ringing and on call disconnect, to see if the SPA3102 is detecting anything strange... In addition, can you please record both tones?
Alberto
georgediam Fri, 04/16/2010 - 04:05
I decided I'd record the tone and analyze it in audacity. It now properly detects the disconnect tone, but apparently not always because a few days later I end up with the SPA's PSTN line being hook off indefinitely again.
Could this be 5.1.10 related? Where can I find an exact description of the disconnect detection bug? I'll revert to 5.1.7 again and see if it helps this time. Is this bug scheduled to be fixed in the next release? It is getting really annoying whatever it is...
georgediam Wed, 04/28/2010 - 08:16
It seems the problem isn't disconnect tone detection related any more... For some reason Music On Hold is activated on the FXO port and it remains hook off forever...
LuckyRoma Fri, 11/05/2010 - 07:21
I have the same problem! I put the right disconnect tone in the PSTN Line Tab, and the softhpone hook on when the remote call hang up, but if I use a on hold music software, the Spa 3102 don't detect when the remote call hang up, so the SPA3102 don't hook on.
This is my configuration Hw/Sw
Linksys SPA3102 Software version 5.1.7  (I had donwgrade it from 5.1.10)
PBX Axon
IMS Telephone On Hold Music
Please Help!!!!!
(sorry for my bad enghlish)
Related Content
