What will happen if Certificates on ASA box expired
Apr 9th, 2010
Hi All,
Just cannot find appropriate document about what affected by Expired Certification on ASA bow.
I use this certificates for Client-to-Site and Site-to-Site VPN.
If you can help answer or point to appropriate docs will be a lot of help.
Thank you very much.
AM.
Jennifer Halim Sat, 04/10/2010 - 00:11
  • Cisco Employee,
If you use certificate to authenticate the vpn client or for site-to-site vpn authentication, with expired certificate, authentication will not work, and you won't be able to establish the VPN tunnel.
You would need to renew the certificate.
amnuaymek Thu, 04/15/2010 - 20:15
Hi halijenn ,
Thank you very much for your answer! Anyway can you leads me to some doc then I can read more
Jennifer Halim Fri, 04/16/2010 - 02:56
  • Cisco Employee,
Since authentication is done via the certificate for remote vpn client and lan-to-lan, if the certificate has expired, it will not able to authenticate, hence, they won't be able to connect. Just like if a password has expired, you were not able to authenticate anymore, hence can't connect through vpn.
Here is a sample configuration on how to renew a certificate:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00809fcf91.shtml
The sample configuration is on how to renew SSL certificate, but the concept is the same for any certificate renewal.
Related Content
