CUCME - Questions
Apr 9th, 2010
How do I get these details on CME router
  • to check if SIP trunk with Nortel is established
  • How many calls where successfully made during last one hour and duration for each call??
  • How much bandwidth does each call takes??
  • what steps are needed to  differentiate the local calls with PSTN calls ( change ringtone ) ; endpoints are sip phones.
thanks
Saquib
paolo bevilacqua Sat, 04/10/2010 - 03:03
  • Hall of Fame,
    Founding Member
- check if it works
- enable CDR logging
- 82 kbps each
- not possible. With sccp phones, is possible.
alig.norbert Sat, 04/10/2010 - 03:05
    • show sip-ua register status
    • the real-time calls can be shown with show sip-ua calls
    • with how sip-ua calls you see the codec/bandwidth as well
Greets,
Norbert
paolo bevilacqua Sat, 04/10/2010 - 03:22
  • Hall of Fame,
    Founding Member
Incorrect, normally SIP trunks between PBXs do not use registration.
