Two links with two Routers to one ISP
Apr 9th, 2010
Dear
I have two links from one ISP and it is terminating on two Routers. How can I configure redundancy with BGP. If one router goes down the other one have to send the traffic. One of the links is Active and the other one is standby.
Overall Rating: 5 (1 ratings)
csawest.dc Sat, 04/10/2010 - 00:13
Dear Ali,
Primary Router:
interface FastEthernet0/0
description secondaary router
ip address 10.10.1.1 255.255.255.0(Ip addresss for the 100 MB Ethet link on my primary router)
no ip redirects
duplex auto
speed auto
standby 1 ip 10.10.1.2
(This puts both routers interfaces in the same subnet, with a common standby group of 1 on that link. So both routers
are responsible for acting together as the virtual router 10.10.1.2 Hosts are configured with a static default gateway,
IP address that of the virtual router, 10.10.1.2 Virtual router)
standby 1 timers 5 15
standby 1 priority 110
standby 1 preempt
standby 1 authentication username
standby 1 track Ether Interface for 100 MB ckt (GE0/0) on this router
Secondar Router:
ip address 10.10.1.3 255.255.255.0 (Ip addresss for the 100 MB Ethet link on my primary router)
no ip redirects
duplex auto
speed auto
standby 1 ip 10.10.1.2 (This puts both routers interfaces in the same subnet, with a common standby group of 1 on that link. So both routers
standby 1 priority 95
standby 1 preempt
standby 1 track Interface of the DS3 Circit on this router
HTH.
Vaib...
chalilakath Sat, 04/10/2010 - 00:32
Dear
In my case I have configured Vlan 630 for the fail over. Please see the configuration below. I need BGP confifuration for the redundancy to the ISP if the active Router fails.
Interface G7/1
Connect_To_Sec
switch port
switch port trunk allowed vlan 100,101,630
switch port mode tru
Interface G7/2
Connect_To_Sec
switch port
Interface vlan 630
ip add 172.16.3.1
stand 63 ip 172.16.3.3 (172.16.3.2 is secondary IP)
standby 63 preemt
paolo bevilacqua Sat, 04/10/2010 - 03:16
  • Hall of Fame,
    Founding Member
Proper BGP configuration requres experience and cannot be done by end users, consequently I recommend you engnage a reputable consltant ot cerfied cisco partner.
