Compatibility between 4400-50 and 5508 Controller
Apr 10th, 2010
Folks,
I have a doubt. I do have at present 4400-50 , which have 50 N-Access Points installed and it is full. This is deployed already. Now I need to add around 80 N-AP's . Can I propose 5508 series controller? Will it be compatible with existing 4400-50 WLAN controller?
Appreciate your help.
SID
Leo Laohoo Sat, 04/10/2010 - 02:07
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Depends on the firmware of the 4400.  If the firmware of the 4400 is 6.X (or later) it should be able to work with the 5508.  I recommend that you transfer all your APs connected to the 4400 to the 5508.
