Unity connection learning material !
Apr 10th, 2010
Hi all. Currently there are no cisco press books for unity connection. I wanted to know that is it possible to understand and configure unity connection using books on just cisco unity ?
Or what path do you guys propose to learn cisco unity connection. Kindly note i have no experience with unity also
David Hailey Sat, 04/10/2010 - 05:50
  • Purple, 4500 points or more
You can learn quite a bit about the basics of Class of Service, Subscriber Templates, Subscriber features, and etc. from the Unity books.  However, the configuration and theory of operation behind each product is completely different.  Unity relies on AD/Exchange for a backend message store (even in a voicemail only configuration) where as Unity Connection is a standalone product.  If you do not know Unity, then I would say that of the two - Unity Connection will be easier for you to pick up on as far as configuration and troubleshooting goes.  For all the CCO docs you'd care to see on Unity Connection, go here:
http://www.cisco.com/en/US/products/ps6509/prod_maintenance_guides_list.htmlhttp://www.ict-partner.net/en/US/products/ps6509/prod_maintenance_guides_list.html
For additional training, you can go to www.ciscounitytools.com and look up Cisco Unity Connection.  There are a number of videos and slide presentations there.  You can also find Unity information there as well.
For Unity, in addition to your books - go here:
https://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_maintenance_guides_list.html
Also read the CUCM SRND and focus on the messaging sections as it discusses deployment topologies, limitations, and etc.
Happy learning...
Hailey
Please rate helpful posts!
