Could GSR12406,IOS 12.0(33)S1 support Local-PBR?
Answered Question
Apr 10th, 2010
Hi Everyone,
I want to know weather GSR12406,IOS12.0(33)S1 support Local PBR or not?
I see the document:http://www.cisco.com/en/US/partner/docs/ios/12_0/qos/configuration/guide/qcpolicy.html#wp5751
It says that the 12.0IOS support Local PBR, but in my plantform isn't support the "ip local policy"command.
Below is my test on my platform:
R-12406-2(config)#ip local
% Incomplete command.
R-12406-2(config)#ip local ?
% Unrecognized command
R-12406-2(config)#ip local policy
% Invalid input detected at '^' marker.
I hope you can help me answer this question,THANK YOU VERY MUCH!
Correct Answer by Giuseppe Larosa about 6 years 10 months ago
Hello Yuan,
it is not a question of IOS version, you need to take in account the specific platform you are dealing with:
a GSR is an high end router that implements distributed CEF and performs forwarding in hardware using ASICs of its linecards, and it is more similar to a multilayer switch then to an ISR router.
The price to pay for very high performance is less features, specially those features that may lead to process switched packets.
Hope to help
Giuseppe
Correct Answer by Leo Laohoo about 6 years 10 months ago
1.  Go to http://tools.cisco.com/Support/Fusion/FusionHome.do
2.  Go to FEATURE/SOFTWARE tab
3.  Category = Router; Series = 12000 series router; Model = 12406; Engine CPU = 12000-PRP
4.  Click Next
5.  Enter "pbr" into the filter, highlight the selection and click the "Add >>>" button and click Next.
6.  License = Service Provider
7.  Click Next.
Don't forget to rate our post.
Have you tried using Cisco Feature Navigator?
www.cisco.com/go/fn
Correct Answer by Paolo Bevilacqua about 6 years 10 months ago
CLI reports error == feature not supported.
Overall Rating: 5 (4 ratings)
yuanyu Sat, 04/10/2010 - 03:30
But,I want to know which version of IOS(major version is 12.0)support this FEATURE?
yuanyu Sat, 04/10/2010 - 03:56
Thanks for your advice!
But I don't know the feature name,
Could you help me?
Correct Answer
Leo Laohoo Sat, 04/10/2010 - 04:21
4.  Click Next
7.  Click Next.
Correct Answer
Giuseppe Larosa Sat, 04/10/2010 - 04:35
Hello Yuan,
Hope to help
Giuseppe
