Configuration Help
Apr 10th, 2010
Hi all,
One of our customer requested for an upgradation, from Exsting 30 channels to 150 channels.Current configuration is attached.Kindly help to configure the same.
Customer requirement.
[1], Additionl PVDM modules on the routers to support more VOIP channel.
[2], Additional 4 E1 ports for voice trunks between router and customer PBX.
[3], Soft upgrade the Internet Access link(LL=10M, port=2M) to Internet Access link(LL=10M, port=2M).
[4], Need to add  120 channel on  IP Trunking gateway.
Current configuration and Diagram attached.
Thanks in advance.
Lijesh
paolo bevilacqua Sat, 04/10/2010 - 06:40
  • Hall of Fame,
    Founding Member
And your question is ?
Please do not solicit for urgent help on a freely contributed user forum.
If you need pre-sale and configuration support, engage a reputable consultant or certified cisco partner.
Lijesh NC Sat, 04/10/2010 - 18:51
Hi  bevilacqua,
I understand the importance of the forum, that was a immediate requirement and i don’t have much knowledge about Voice related things.
Would be helpful if you can give some inputs on this.
Thanks in advance.
Lijesh
paolo bevilacqua Sun, 04/11/2010 - 04:13
  • Hall of Fame,
    Founding Member
Since you have no experience, I recommend you engage a reputable professional or certified partner.
Otherwise, it will be impossible for you to satisfy your customer requests.
