04-10-2010 10:28 PM - edited 03-04-2019 08:06 AM
I'm trying to match LWAPP/CAPWAP traffic, so that it's classified as critical traffic for our outbound QoS policy that's applied on the CE WAN router.
There are hits on ACL, but when I look at "show policy-map interface", stats is zero.
So my question is if matching ACL along w/ DSCP is a valid configuration within MQC?
ip access-list extended LWAPP
permit udp any any eq 12223
permit udp any any eq 5246
permit udp any eq 12223 any
permit udp any eq 5246 any
class-map match-any missioncritical
match ip dscp cs3 af31 af32 af33 cs6 cs7
match access-group name LWAPP
policy-map CHILD-POLICY
class realtime
priority 2048
police 2048000 conform-action transmit exceed-action drop
class priority
bandwidth remaining percent 30
random-detect dscp-based
class missioncritical
bandwidth remaining percent 20
class transactional
class general
bandwidth remaining percent 10
class class-default
policy-map PARENT-POLICY
class class-default
shape average 8500000
service-policy CHILD-POLICY
interface FastEthernet0/0/0.2
service-policy output PARENT-POLICY
Router#sh access-list LWAPP
Extended IP access list LWAPP
10 permit udp any any eq 12223 (3837 matches)
20 permit udp any any eq 5246
30 permit udp any eq 12223 any (466137 matches)
40 permit udp any eq 5246 any (14184 matches)
Router#show policy-map int fa0/0/0.2
FastEthernet0/0/0.2
Class-map: missioncritical (match-any)
2610146 packets, 811329309 bytes
30 second offered rate 11000 bps, drop rate 0 bps
Match: ip dscp cs3 (24) af31 (26) af32 (28) af33 (30) cs6 (48) cs7 (56)
2124221 packets, 330567230 bytes
30 second rate 0 bps
Match: access-group name LWAPP
0 packets, 0 bytes
04-11-2010 04:06 AM
Hello Huangedmc,
your configuration is correct because you have used match-any in defining the class-map.
The question can be: are you using any form of tunneling and/or encryption on the WAN interface that could hide the traffic flows?
DSCP settings are propagated to external headers both for GRE and IPSec so it is possible to match on them even if you are using tunnels and/or IPSec.
Another possible hint is: if the LWAPP packets are marked with a DSCP value matched by first match for the match-any directive there is no need to have them processed by second match statement to be classified in this traffic class.
Hope to help
Giuseppe
04-12-2010 05:06 AM
Thanks for the response.
No, we are not doing encryption / IPSec, or GRE on the CE, but you had a good point about matching DSCP before ACL.
I changed the order, so that the ACL comes first:
Now both class-maps have zero packets:
3507010 packets, 942960979 bytes
30 second offered rate 14000 bps, drop rate 0 bps
0 packets, 0 bytes
0 packets, 0 bytes
Do you know if there would be matches only if congestion is experienced on the interface?
Wouldn't QoS only kick in when there's congestion, like when the interface hardware queue is full?
04-12-2010 05:12 AM
Hello Huangedmc,
counters should be updated even when congestion is not present, I've seen this behaviour on several platforms including C7200, C7500, and other ones.
Actually this is a way to know traffic per traffic class over time.
What you see is strange, what device is this and what IOS image is running on it?
Hope to help
Giuseppe
04-12-2010 05:29 AM
This is a 2821 running 12.4(24)T1, ADVIPSERVICESK9.
The circuit is terminated on a fast ethernet HWIC card (fa0/0/0).
It's physically provisioned as 100M/full, but the actual circuit rate is 10M.
Even though the stats are zero under each class, the class-map itself shows some matching traffic however:
0 packets, 0 bytes
0 packets, 0 bytes
I checked on the 7206VXR, also running 12.4(24)T1, ADVIPSERVICESK9 at our head-end.
Stats are non-zero under this class.
However, we have not configured the second matching statement (against ACL) on this router yet, so it's not exactly apples to apples.
124339798 packets, 55580257642 bytes
5 minute offered rate 24000 bps, drop rate 0 bps
124339799 packets, 55580257642 bytes
5 minute rate 24000 bps
Edit:
Before we added the second matching statement against the ACL, I'm pretty sure there were matches against the ip dscp match under the class-map.
I just checked on another 2821 running the same IOS code at a different location, and confirmed that's the case:
30838116 packets, 4765524600 bytes
5 minute offered rate 19000 bps, drop rate 0 bps
5 minute rate 19000 bps
Does this mean when there's more than one matching statement, IOS can't tell how many packets are matched under the same class?
Message was edited by: huangedmc
