LMS 3.1 JRM Service could be down. Check whether JRM services are running.
Answered Question
Apr 10th, 2010
Hi all
Jrm service is showing down in LMS 3.1.
When i select RME tab its showing the error " JRM Service could be down. Check whether JRM services are running."
I checked the services.But its running.
We have not changed the host name.
Pls find attached the lms service status as well.
If any one faced the same issue pls reply me at the earliest.
Thanks and regards
Danish
Correct Answer by Joe Clarke about 7 years 1 month ago
Based on these services, this appears to be LMS 2.x, not 3.1.  Post the output of the pdshow command.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Overall Rating: 5 (1 ratings)
danishahammed015 Wed, 04/14/2010 - 12:50
Hi clark thanks for your reply
I had restarted all the services using the command net stop crmdmgtd and net start crmdmgtd.Now it seems to be working.
-Danish
