Cisco-Panasonic Integration
Apr 11th, 2010
I am trying to do an integration between CUCM 7 and Panasonic TDA-200 through an E1 port.
However, I have this weird problem.
I can dial from the PBX to the individual IP Phones without an problems.
However, when I try to dial from the IP Phone to a certain PBX extension, it always goes to the another extension.
I did the debugs, I don't see any errors. I send the extension correctly being sent out.
Whatt could be the problem?
Any ideas?
Ahmed
Aaron Harrison Sun, 04/11/2010 - 01:56
  • Community Spotlight Award,
    Member's Choice, May 2015
In general, if you are certain you are sending out the numbers in a consistent and correct format, then there is likely to be something unexpected happening on the Panasonic. There may be some unexpected translations or so on happening; if you don't manage the Panasonic yourself you'll need to engage the engineer on that side to assist.
Aaron
Please rate helpful posts..
AhmedEl-Eraky Sun, 04/11/2010 - 07:28
Hello Aaron,
Yeah, I think so. The debug doesn't show anything strange.
Although, I'm trying to call extension (230), the router outputs "230", but another extension is always being called. "211"
I also think it's the PBX but I want to rule out that the router is missing something, like called-number or other signaling parameters.
I tried different commands such as: "isdn outgoing display-ie" or "isdn outgoing ie called-number" as well as fiddled a bit with other commands under the serial-port. I also changed the switch-type to QSIG and still no difference at all.
The IOS version is Flash:c2800nm-spservicesk9-mz.124-15.T9.bin
Kindly find excerpt of the configuration and debug below:
controller E1 0/2/0
clock source internal
pri-group timeslots 1-31
interface Serial0/2/0:15
description <>
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
dial-peer voice 8800 pots
tone ringback alert-no-PI
description **<>**
destination-pattern 8...
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/2/0:15
prefix 1
***CISCO TO PANASONIC CALL***
HQ-Gateway-1#
000174: Apr 11 15:23:24: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 40003
000175: Apr 11 15:23:24: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 1230
000176: Apr 11 15:23:24: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0083
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0081, '40003'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '1230'
000177: Apr 11 15:23:24: ISDN Se0/2/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8083
000178: Apr 11 15:23:24: ISDN Se0/2/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8083
000179: Apr 11 15:23:30: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0083
        Cause i = 0x8290 - Normal call clearing
000180: Apr 11 15:23:30: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8083
000181: Apr 11 15:23:30: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0083
HQ-Gateway-1#
***PANASONIC TO CISCO CALL***
HQ-Gateway-1#
000150: Apr 11 15:20:39: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0042
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
        Channel ID i = 0xA1839F
                Preferred, Channel 31
        Calling Party Number i = 0x0080, '1230'
        Called Party Number i = 0x80, '4'
000151: Apr 11 15:20:39: ISDN Se0/2/0:15 SERROR: process_pri_simple: NO name in GTD
000152: Apr 11 15:20:39: ISDN Se0/2/0:15 Q931: TX -> SETUP_ACK pd = 8  callref = 0x8042
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
000153: Apr 11 15:20:39: ISDN Se0/2/0:15 Q931: RX <- INFORMATION pd = 8  callref = 0x0042
        Called Party Number i = 0x80, '0'
000154: Apr 11 15:20:40: ISDN Se0/2/0:15 Q931: RX <- INFORMATION pd = 8  callref = 0x0042
000155: Apr 11 15:20:40: ISDN Se0/2/0:15 Q931: RX <- INFORMATION pd = 8  callref = 0x0042
000156: Apr 11 15:20:40: ISDN Se0/2/0:15 Q931: RX <- INFORMATION pd = 8  callref = 0x0042
        Called Party Number i = 0x80, '3'
000157: Apr 11 15:20:40: ISDN Se0/2/0:15 SERROR: process_pri_simple: NO name in GTD
000158: Apr 11 15:20:40: ISDN Se0/2/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8042
000159: Apr 11 15:20:40: ISDN Se0/2/0:15 SERROR: process_pri_simple: NO name in GTD
000160: Apr 11 15:20:40: ISDN Se0/2/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x8042
        Progress Ind i = 0x8188 - In-band info or appropriate now available
000161: Apr 11 15:20:54: ISDN Se0/2/0:15 SERROR: isdn_get_name_from_gtd: false ret
000162: Apr 11 15:20:54: ISDN Se0/2/0:15 SERROR: process_pri_simple: NO name in GTD
000163: Apr 11 15:20:54: %ISDN-6-CONNECT: Interface Serial0/2/0:30 is now connected to 1230 N/A
000164: Apr 11 15:20:54: ISDN Se0/2/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x8042
000165: Apr 11 15:20:54: ISDN Se0/2/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x0042
000166: Apr 11 15:20:59: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:30, changed state to up
000167: Apr 11 15:21:00: %ISDN-6-CONNECT: Interface Serial0/2/0:30 is now connected to 1230 N/A
000168: Apr 11 15:21:02: %ISDN-6-DISCONNECT: Interface Serial0/2/0:30  disconnected from 1230 , call lasted 7 seconds
000169: Apr 11 15:21:02: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x8042
000170: Apr 11 15:21:04: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x0042
        Cause i = 0x8190 - Normal call clearing
000171: Apr 11 15:21:04: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8042
HQ-Gateway-1#
Any ideas?
Ahmed
Aaron Harrison Sun, 04/11/2010 - 12:13
You say mention 230, and the call ending up on 211... but on your ISDN debug you are sending out 4 digits (1230)?
Depending on how the trunk is configured on the Panasonic end, if you send in an unexpected digit length it might confuse things. If the Panasonic is using 3-digit extensions, find out if you should be sending three digits or more..
The debug isdn q931 shows exactly what is signaled out the ISDN, so what you see there is what should be received at the Panasonic. If it looks OK to you there, get in touch with the Panasonic eng and show him what you are sending...
Aaron
