Load balaning and rtr redundancy over WAN link
Apr 11th, 2010
Hi all,
I am trying to get load balancing over 2 wan(isp link) and router redundency as well.. but failed to get the solution..
Now need expert suggestion to achive it..
I have attached the diagram for reference...
Scenario:
Routers(3845) connected to 2 ISP, traffic need to be shared on both.
ASA 5520 configured in routed mode, active - failover and doesnot support PBR to load balance at ASA level.
Static route is being used..
I tried below things and failed..
1. GLBP on router to do load balacing and router redundancy:
Prob: GLBP work best with multiple clients.. in diagram there is only one client i.e ASA..
2. I tried giving 2 default route at ASA but not working when one fails or any WAN links fails..
next POA..
Now i am goin to use OSPF on routers, ASA and L3 switches in LAN.. not sure if this will work fine..
Need expert suggestion on it..
amar
amardram123 Sun, 04/11/2010 - 20:55
As you can see in diagram i am having two routers and behind it ASA 5520, which doesnt support PBR.
Can i use OSPF for load balance?
Amar
Paolo Bevilacqua Sun, 04/11/2010 - 23:40
I don't think it would work. Use a single router, elimiante the ASA, it will work and and be much simpler.
amardram123 Mon, 04/12/2010 - 02:03
Cust need router redundency so need to have two router and cust also wants ssl/ra on ASA..
regards
Amar
