IP Phone 7942G does not start after factory reset
Apr 11th, 2010
Dear All:
I am new with this equipments and I do not have idea how to start to solve this problem.
My Cisco IP Phone 7942 does not start after factory reset.
It stopped in a Cisco splash screen with a circle with a dot inside.
Please, I would be grateful for your help.
Alano
paolo bevilacqua Sun, 04/11/2010 - 08:58
  • Hall of Fame,
    Founding Member
Are you the system administrator ?
alanoarraes Sun, 04/11/2010 - 12:16
Hi p.bevilacqua,
yes, I am the system administrator.
Thks,
Alano
Aaron Harrison Sun, 04/11/2010 - 12:06
  • Community Spotlight Award,
    Member's Choice, May 2015
Generally this means that your one of either your DHCP/TFTP/files on TFTP has a problem.
Phones will often run whatever firmware they have if there is a problem with your TFTP setup, but when you fact reset them everything must be working.
What call processing system are you running?
Aaron
alanoarraes Sun, 04/11/2010 - 12:20
Hi Aaron:
I perfomed the following steps:
1) unplug the cable(poe) and turn off the equipment;
2) plug the cable in the POE Switch and press "#" and release;
3) while the line lights blinking I entry with the sequence "123456789*0#"
After the steps above the equipment start an upgrading, retrieve an IP and stop in the Splash Screen with a circle with a dot inside.
I repeat this process many times without sucess.
Thks,
Alano
Aaron Harrison Sun, 04/11/2010 - 12:23
Yeah, I know what you've done
What I don't know is what call processing system you are using. What you need to do to fix it will vary.
alanoarraes Sun, 04/11/2010 - 12:27
Hi Aaron,
I apologize because I did not understand very well your last question
The call processing system that I would like to use is Elastix(Asterisk).
Thks,
Alano
Aaron Harrison Sun, 04/11/2010 - 13:36
No problem...
Basically what's going to happen is that the phone is going to boot and download a file named term41.default.loads
You will need to ensure that you are serving up DHCP with option 150 set to a TFTP server, and that your TFTP server has the term41.default.loads file. This file contains pointers to a bunch of other files. Open the file in a text editor, and verify that you have each of the files listed in it available on your TFTP server.
You should be able to see from the TFTP server logs what files are requested, and where it stops.
Aaron
alanoarraes Sun, 04/11/2010 - 13:44
Hi Aaron:
this equipment is conect to a Switch POE and the Switch to the internet through a router.
The router is the DHCP and it give an ip to the IP Phone.
I did not setup a DHCP server or TFTP server.
Could you explain how can I do it?
I apologize for this basic questions.
Thks,
Alano
Aaron Harrison Sun, 04/11/2010 - 13:54
Well - you need to obtain some firmware for the phone firstly. You can download from Cisco if you have access rights; or find it somewhere else.
When you have it, unzip it onto the root of a tftp server like tftpd32 (google it).
You will need to set up a DHCP server that can supply option 150 to the phone, which tells the phone where the TFTP server is. You may be able to get your router or switch to do it - are either of those Cisco kit?
Aaron
alanoarraes Sun, 04/11/2010 - 14:12
Hi Aaron:
I setup the TFTP server in the server of Elastix and dowload a SIP Image in the root.
One question: my phone is connect to a router (Cisco RV042) that is serving DHCP? Is it possible tell in the router that my TFTP Server is on my Elastix Server by port redirecting?
Please, could you give an idea about that?
Thks,
Alano
Aaron Harrison Sun, 04/11/2010 - 15:10
I've no idea about what an RV042 can do... basically you need to add a custom option, id 150, type IP, and the IP should be your TFTP server.
If you can't get the router to do it, use another DHCP server and disable the one on the router temporarily.
Aaron
alanoarraes Sun, 04/11/2010 - 15:39
Hi Aaron:
I setup my router to foward the port 69 to my tftp server but it is not working yet.
The scheme that I am using is :
Modem ADSL ---> Router RV042 ---> Switch POE ---> Cisco IP Phone 7942.
Do you have some sugestion?
Thks, Alano
Aaron Harrison Sun, 04/11/2010 - 21:56
As I said in the earlier post, you need to make the files available on a TFTP server.
You also need to tell the phone where the TFTP server is, and to do this you need to configure the custom option I mentioned on your DHCP server.
Alternatives to this are listed at this URL; be aware that as you have done a factory reset you can't access the menus, so can't set a locally configured TFTP server on the phone. You need to use one of the other methods, and I would strongly recommend the Option 150.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_0_1/ccmsys/a0...
As I said earlier, if your router isn't advanced enough to allow configuration of custom DHCP options, you will need to set up another DHCP server that does.
Aaron
riko.arizona Mon, 04/12/2010 - 03:43
try to "debug tftp events"
then "ter mon"
Step 1:
perfomed the following steps that you mentioned before:
please post debug result.
For example :
Apr 12 09:02:48.282: %SYS-5-CONFIG_I: Configured from console by gmr on vty0 (172.21.84.142)
Apr 12 09:03:25.410: TFTP: Looking for term11.default.loads
Apr 12 09:03:25.410: TFTP: Opened flash:term11.default.loads, fd 7, size 662 for process 196
Apr 12 09:03:25.414: TFTP: Finished flash:term11.default.loads, time 00:00:00 for process 196
Apr 12 09:03:26.510: TFTP: Looking for jar11sccp.8-4-1-23.sbn
it said that TFTP is looking for file jar11sccp.8-4-1-23.sbn.
do "sh flash command". Make sure file jar11sccp.8-4-1-23.sbn, is in flash directory.
add this command "tftp-server flash:jar11sccp.8-4-1-23.sbn".
do step 1 again, and see from debug result, what file is TFTP looking for.
Repeat for step 1 until you see
"Apr 12 09:08:07.502: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-9:SEP0026CB3D9 IP:x.x.x.x. Socket:5 DeviceType:Phone has unregistered abnormally."
then it will restart again. When restart finish, you will see
"Apr 12 09:11:02.010: %IPPHONE-6-REGISTER: ephone-9:SEP0026CB3D9 IP:x.x.x.x Socket:5 DeviceType:Phone has registered.
Aaron Harrison Mon, 04/12/2010 - 03:59
Suspect he'll struggle to do that on Asterisk..?
ftahhan00 Tue, 11/23/2010 - 01:31
Hi Aron
can i install tftp server on my PC and put that firmeware on my PC then connect the IP phone 7942 which is not working and let boot and take the TFTP from my PC, it's possible.
thanks
Fadi
Dan Walker Wed, 08/29/2012 - 10:49
This type of an issue occurs when the phone is configured and connected as a VPN Client through an ASA.
webgourou Thu, 10/25/2012 - 07:57
hello,
do you have any issue to configure the phone while he is "upgrading"...
There is no way to configure the TFTP server adress in it...
Aurel
Related Content
