Cue attendant scripts dial by extension
Answered Question
Apr 11th, 2010
Does anyone have an example script for CUE 7.0? CCO is having some example scripts, but I can't find any dial by extension scripts. I see the dial by extension option in the media folder of CUE editor but I can't get it to work. What I am looking for is this:
Check for office hours (no> voicemail)  >
Welcome, dial 1 for English, dial 2 for Spanish >
Main Menu (desired language)
You may dial an extension at any time (1XXX),  press 2 for department A,  press 3 for department B.
Thanks in advance,
Overall Rating: 5 (1 ratings)
Rob Huffman Mon, 04/12/2010 - 05:54
Hi Jeroen,
The "Example" scripts can be found @ this path
Cisco> Support> Tools and Resources> Software Downloads>  Voice and Unified Communications> Unified Communications Applications> Voice Mail and Unified Messaging> Cisco Unity Express Version 7.0> Unity Express Auto-Attendant Scripts> 7.1.1> CUE-AA-S4-DialbyName-2.3.1.zip
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
jeroenmaat Mon, 04/12/2010 - 06:26
Thanks for your answer.
I just tried that script but that is only having a dial by name option, no dial by extension...
- Jeroen
jeroenmaat Sat, 05/08/2010 - 12:00
Hi Rob,
Thanks, I used you document in combination with an example script which is recently uploaded in the 7.1.5 example script folder. The script is working fine now.
