7936 Conference station softkey disabled
Apr 11th, 2010
I have registered a 7936 conference station on my UCM 7.1
The conference station registered but the softkey is not active.
Appreciate your support
Overall Rating: 5 (1 ratings)
Aaron Harrison Mon, 04/12/2010 - 00:52
  • Community Spotlight Award,
    Member's Choice, May 2015
What softkey?
That the 7936 is called a 'conference' station doesn't mean anything other than that the phone was designed for use in conference rooms.
It has lots of softkeys.
Aaron
sayeedibrahim Mon, 04/12/2010 - 23:24
True that 7936 is a conference station. It is registered and has an extension assigned to it but the buttons are not active to answer or make calls/conferences.
Aaron Harrison Mon, 04/12/2010 - 23:26
Can you screen grab the configuration pages from CallManager for the device and line?
Aaron
Aaron Harrison Tue, 04/13/2010 - 07:02
Nope.
Don't have one lying around.
I was suggesting you post yours so we can verify your config.
David Hailey Tue, 04/13/2010 - 07:07
  • Purple, 4500 points or more
Go to Phone Configuration for the device.  Look at the "Softkey Template" field.  If it is set to then you won't have softkeys available.  This is not a required field and since many folks only enter data in required fields, it is often missed.
Verify this setting and then get back to us.
Hailey
Please rate helpful posts!
Rob Huffman Tue, 04/13/2010 - 07:43
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ibrahim,
Just to follow up on the tips from Aaron and Hailey
You mentioned this in your clip;
"It is registered and has an extension assigned to it but the buttons  are not active to answer or make calls/conferences."
To start a call or answer a call on a 7936 no Softkey is required, you just press the
button with the Handset icon on the 7936.
For MeetMe;
1. press the pick up handset to get dial tone
2. Press Menu button > Call functions > Meet Me
3. Enter the meet me number.
Hope this helps!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
sayeedibrahim Wed, 04/14/2010 - 02:14
Hey everybody
Thanks for your advices. Attached are the screen shots of Conference Station device config page on CCM
Currently i can place a call from conference station but cannot make any conference calls. Also I cannot answer any incoming call.
The answer, transfer, conference -- all these keys are greyed on the device display. Handset button is also not working.
sayeedibrahim Fri, 04/16/2010 - 23:08
What is the normal procedure for registering the conference station
sayeedibrahim Wed, 05/05/2010 - 05:38
I opened a TAC case and cisco engineer confirmed that there is a hardware issue and they are replacing my conference station @ RMA
Rob Huffman Wed, 05/05/2010 - 05:46
  • Hall of Fame,
    Founding Member
Hi Ibrahim,
Thanks for following up with your resolution here
+5 points for letting us know the final outcome.
Cheers!
Rob
