Cisco ASA 5540 - [%ASA-3-210005: LU allocate connection failed]
Apr 12th, 2010
Hi experts,
I am getting the following error on my two different set of Cisco ASA 5540 (Failover bundle). I am using the 8.2(2) Software version. But, we used to receive the below syslog messages on STANDBY device & error frequency is HIGH.
04-06-2010      12:20:54        Local4.Error    192.168.4.6     Apr 06 2010
05:09:14: %ASA-3-210005: LU allocate connection failed
04-06-2010      12:21:29        Local4.Error    192.168.4.3     Apr 06 2010
12:15:23: %ASA-3-210005: LU allocate connection failed
I have checked the syslog messages detail & found some relevant solutions like (http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsb98925) & (http://www.ciscotaccc.com/kaidara-advisor/SearchflowRes.do) but so far, result is the same. I believe, it's a software bug which needs to be fix.
Kindly, provide your comments.
Thanks in advance.
Mubasher Sultan
