Personal Communicator no Presence State
Answered Question
Apr 12th, 2010
I configured a Presence Server with Personal Communicator. The Presence server have a LDAP Connection. I can add users. The problem I have is that I see no Presence state at the communicator. At the communicator at the check everything is green.
Where can I search to solve the problem?
thanks Achim
Correct Answer by Aaron Harrison about 6 years 9 months ago
You mean you aren't seeing the 'on the phone' status, but everything else is OK?
In that case, you need to go to each users' line, and associate the line with the user. This is done from the bottom of the line appearances' configuration page.
To configure this in bulk using BAT, see:
https://supportforums.cisco.com/message/3043177#3043177
Aaron
Please rate helpful posts..
Overall Rating: 5 (1 ratings)
Aaron Harrison Mon, 04/12/2010 - 01:23
In 'Show Server Health' in the CUPC client, what does the 'Presence' server show?
Aaron
astrohmeier Mon, 04/12/2010 - 01:35
the Presence server state is online.
I see some users in green that are logged on to the Personal Communicator. One is yellow because he configured nit Communicator to show him after 30 minutes as offline. What I do not see ist the state of the phone.
any idea?
Achim
astrohmeier Mon, 04/12/2010 - 01:57
at the Presence Server User configuration I see that under Devices Associated Lines I see at Presence State unknown.
What do I have to configure that I see something at this point?
Achim
htluo Mon, 04/12/2010 - 05:25
Check the following:
1) On CUCM > Device > Trunk.  Make sure you have a SIP trunk pointing to the IP address of CUPS, port 5060.
2) On CUCM > System > Service Parameters > Cisco CallManager, make sure CUP Publish Trunk was configured as the trunk above.
3) On CUCM > Device > Phone, click on the DN configured on the phone.  Go to the bottom of the page.  Make sure end user ID was associated with the DN.
If all checked out but still not work, do the following:
1) On CUCM > Device > Trunk, reset the trunk.
2) On CUPS > Serviceability >Tools - Feature Services, restart "Cisco UP Presence Engine"
3) On CUCM > Device > Phone, reset the phone.
Michael
http://htluo.blogspot.com
Correct Answer
Aaron Harrison Mon, 04/12/2010 - 02:14
Aaron
